If you backed up data in Nokia, you can put Nokia into Recovery Mode to remove screen lock, you can restore from backup files after unlocking Nokia. Or you can use the tool -Eelphone Android Unlock to unlock Nokia without password.Nokia 5.1 plus phone after 1 day not getting unlock. We entered correct password only. Pls suggest any one how to resolve it
No, after entering pattern showing wrong pattren, i have entered more than 100 times but phone not getting locked. I dont have any data on it. I want to do factory reset but for that to asking pattren. My self is it possible to do or need to carry to service center?is there a forget pattern or password option? if there is, is should ask you for your google acct info that was first used to set up the phone.
Hi ocnbrzeNo, after entering pattern showing wrong pattren, i have entered more than 100 times but phone not getting locked. I dont have any data on it. I want to do factory reset but for that to asking pattren. My self is it possible to do or need to carry to service center?
