Noncharging Charger
Rgarner
Android Expert
A great Christmas gift would be a Charger rc car. This one's a black beauty, Dom's ride from Fast and Furious. The only problem is it seems not to be charging. There is a usb cord that folds up in a compartment on the underside of the car. Just add a wall wart. Originally it worked fine. Then it was put away for a while and it doesn't run. The red light comes on fine when it is switched on and the red light on the controller works, too. It probably doesn't need new contoller batteries.
I guess you mean different wall wart. I probably should. I know the outlet is live because it works fine with the vacuum cleaner.
How do I know? There was no wall wart included. I guess the manufacturer assumes that the purchaser has that readily available.
most devices that do this usually require the standard phone charger. i do not think it needs anything like a fast charger. it could also be the cable or even the car itself. if a new charger does not work, then you might have gotten a lemon rc car. hopefully you can still return it.
