Help Not able to flash a new custom ROM on Micromax A102 Doodle 3
Sury50
I am trying to install a new ROM on my phone. I wanted to install Emotion Lollipop ROM, but I was not able to do it.
I have flashed a custom recovery [Carliv Touch Recovery] with SP Flash tools and it works fine, and while installing the new ROM, it showed me that it has been successfully installed but when I reboot the phone then it shows the Micromax LOGO and then doesn't show any boot animation.Its just black with a little bit of backlight.
I have tried several ways to solve this problem but none of them worked.
Can anyone help me to get out of this situation?I have also deleted the backups accidentally!I want to fix this phone but I am unable to do this.
I've never heard of that recovery. Is there no CWM or TWRP available for your device? Do you have an sd card slot and/or do you have "USB debugging" enabled in developer options?
Yes, its a a CWM recovery customized by Carliv.
I don't know about "USB debugging", but before flashing ROM I have turned it ON and then Wiped everything then installed the ROM and I have an External SD card also.
(thanks for reply)
