jugaldesai
i am trying to connect to VidyalankarLive.com
and the login page is Vidyalankar Live
the problem is that when i click the login button it tries to connect and in response i just get the login page back.
I am not able to figure out what the problem i actually.
code
CoustomHttpClient.java
LoginLayout.java
main.xml
code
Code:
package com.example.login;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.net.URI;
import java.util.ArrayList;
import org.apache.http.HttpResponse;
import org.apache.http.NameValuePair;
import org.apache.http.client.HttpClient;
import org.apache.http.client.entity.UrlEncodedFormEntity;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.conn.params.ConnManagerParams;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.params.HttpConnectionParams;
import org.apache.http.params.HttpParams;
public class CustomHttpClient {
public static final int HTTP_TIMEOUT = 30 * 1000; // milliseconds
private static HttpClient getHttpClient() {
if (mHttpClient == null) {
mHttpClient = new DefaultHttpClient();
final HttpParams params = mHttpClient.getParams();
HttpConnectionParams.setConnectionTimeout(params, HTTP_TIMEOUT);
HttpConnectionParams.setSoTimeout(params, HTTP_TIMEOUT);
ConnManagerParams.setTimeout(params, HTTP_TIMEOUT);
return mHttpClient;
public static String executeHttpPost(String url, ArrayList<NameValuePair> postParameters) throws Exception {
BufferedReader in = null;
try {
HttpClient client = getHttpClient();
HttpPost request = new HttpPost(url);
UrlEncodedFormEntity formEntity = new UrlEncodedFormEntity(postParameters);
request.setEntity(formEntity);
HttpResponse response = client.execute(request);
in = new BufferedReader(new InputStreamReader(response.getEntity().getContent()));
StringBuffer sb = new StringBuffer("");
String line = "";
String NL = System.getProperty("line.separator");
while ((line = in.readLine()) != null) {
sb.append(line + NL);
in.close();
String result = sb.toString();
return result;
} finally {
if (in != null) {
try {
in.close();
} catch (IOException e) {
e.printStackTrace();
public static String executeHttpGet(String url) throws Exception {
try {
HttpGet request = new HttpGet();
request.setURI(new URI(url));
String line = "";
in.close();
return result;
} finally {
if (in != null) {
try {
in.close();
LoginLayout.java
Code:
import org.apache.http.message.BasicNameValuePair;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
public class LoginLayout extends Activity {
EditText un,pw;
TextView error;
Button ok;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
un=(EditText)findViewById(R.id.et_un);
pw=(EditText)findViewById(R.id.et_pw);
ok=(Button)findViewById(R.id.btn_login);
error=(TextView)findViewById(R.id.tv_error);
ok.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
ArrayList<NameValuePair> postParameters = new ArrayList<NameValuePair>();
postParameters.add(new BasicNameValuePair("vb_text_username", un.getText().toString()));
postParameters.add(new BasicNameValuePair("vb_text_password", pw.getText().toString()));
String response = null;
try {
response = CustomHttpClient.executeHttpPost("http://www.vidyalankarlive.com/site/login.php", postParameters);
String res=response.toString();
/*i am guessing that there must be some problem in here cause the website dosent have response for 1 or 0
but at least when i print the res it must show me the logged in info right?? */
if(res.equals("1"))
error.setText("Correct Username or Password");
else
error.setText("Sorry!! Incorrect Username or Password");
} catch (Exception e) {
un.setText(e.toString());
main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="fill_parent"
android:layout_height="match_parent"
android:layout_marginTop="10dip"
android:background="#DDDDDD">
<TextView
android:id="@+id/tv_un"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:textSize="10pt"
android:textColor="#444444"
android:layout_alignParentLeft="true"
android:layout_marginRight="9dip"
android:layout_marginTop="20dip"
android:layout_marginLeft="10dip"
android:text="User Name:"/>
<EditText
android:id="@+id/et_un"
android:layout_width="150dip"
android:background="@android:drawable/editbox_background"
android:layout_toRightOf="@id/tv_un"
android:layout_alignTop="@id/tv_un" android:text="@string/jugaldesai"/>
<TextView
android:id="@+id/tv_pw"
android:layout_below="@id/tv_un"
android:layout_marginTop="15dip"
android:text="Password:"/>
<EditText
android:id="@+id/et_pw"
android:layout_toRightOf="@id/tv_pw"
android:layout_alignTop="@id/tv_pw"
android:layout_below="@id/et_un"
android:layout_marginLeft="17dip"
android:password="true" android:text="@string/jacky123"/>
<Button
android:id="@+id/btn_login"
android:layout_width="100dip"
android:layout_below="@id/et_pw"
android:layout_marginLeft="110dip"
android:text="Login" />
<TextView
android:id="@+id/tv_error"
android:layout_height="40dip"
android:textSize="7pt"
android:layout_below="@id/btn_login"
android:layout_marginLeft="15dip"
android:textColor="#AA0000"
android:text=""/>
</RelativeLayout>
