Help Not enough space ?! Please take a look
Hey,
I am an owner of Huawei Ascend Y530,anyway i have problems with not enough space.
I have about 1 gb all toggether(somewhere says 4 gb but thats just weird),anyway i ve deleted a lot of media stuff such as music and now i have more than 600 mb free BUT when i want to update some apps or download some it says i dont have enough memory.So i went to look my memory space and it says my apps take about 0,9 of 1 gb lol
Anyway how to change it?
there are 3 different "spaces" in android 1.system partition 2. internal SD and 3. external SD (micro SD card)
your problem is that your system partition is full. This phone has weak Memory (4GB) it´s parted to 1GB of system partition and 3GB of internal partition. I bet your system apps use a really exciting amount of 400-500MB so u can install only a few apps. (warning: if u reach a limit of space [depends on phone] there wont be enough space to cache so your phone will slow down. )
My opinion:
never decide to take the cheapest phone on the list. Always check the ROM memory and the RAM memory, apps get larger after every update, take this in mind.
I understand totally,i ve noticed the apps gets bigger after every update.
Anyway i have Samsung Galaxy S3 mini,do you think its better than my current one?
Samsung S3 Mini: 2012 , Camera : 5Mpx (i stick with samsung), Memory :8/16GB (samsung wins the round), RAM 1Gb (Samsung wins again), Android 4.1.2 (maybe stable if u use it wisely 1GB RAM is enough to run this OS)
Huawei Ascend Y530: 2014 , Camera : 5Mpx (i stick with samsung) , Memory : 4Gb(samsung wins the round) ,RAM 512MB(Samsung Wins Again) Android 4.3 (This kind of android with 512mb of RAM is not even stable samsung wins again)
Yes, your samsung is better than the Huawei Ascend Y530. The problem of these phones are the CPU s with the Dual Core 1,0Ghz. Actually the Huawei wins the CPU round with the 1,2 Dual Core. But in your place i would use the samsung.
Thanks man,really appreciate it.
Anyway,i just want a phone i can use fb,messanger,whats app messanger,instagram and i can store images.Nothing more.Maybe few more apps but nothing major.
I though of using Huawei just to listen music too ...
