Not Enough Space
  • Thread starter Thread starter Catdureazaa
  • Start date Start date
C
Catdureazaa
Guest
Hello world! I want to install an app what have 39,16 MO, is named Terraria (can be finded in Play Store). I have on my Internal Space 65,00 MO and on my SD card 2,5 GB. When I install it, I get an error what says cuz i don't have enough Space .. I restarted the phone 5 times, and nothing. What can I do?
Hi
Most apps get bigger when you install them because the file size on playstore is the package size before installation. You probably need more than 65mb. EgMaps is less than 8mb on playstore but is 53mb when installed!
If you are on v4 android you can't install apps to sd (some can be on the very latest version) unless you root the phone. On earlier versions it depends if the developer supported the feature.
Roger
Hi
Roger
Hey, i'm that Guest. Can you say me how can I save my apps from PlayStore on the SD Card? I have a Samsung Galaxy Fit, Android v 2.3.4 Gingerbread
thanks
Hi
I have not used a samsung phone on gingerbread. But:
To move an app to sd you first have to install it on the phone, so you need to move other apps to sd to make space for your game before moving it to sd. On htc phones you do this by
Menu button
Settings
Sd & phone storage
Make more space
Press next to clear caches
Select move apps to sd
Choose which apps and press next.
It is probably different on Samsung but the same idea.
Roger
Hi
Menu button
Settings
Sd & phone storage
Make more space
Roger
Thanks, but isn't any option to make the apps to be saved from the first time on the SD Card? I don't have enough space in the Internal Memory ...
Hi
I am not aware of any way to download from playstore directly to SDcard. The android installer always installs to internal storage afaik.
Roger
