not enough space
  • Start date Start date
A
Android Question
Guest
About once per day I have to reboot my phone because it says "not enough space", and won't allow me to respond to texts or anything.. what is the solution for this?
Hi and Welcome to the forums
Is because your phones internal memory is full. Each time you reboot you delete the temporary files making a little space so it works for a while.
You need to move some files to sd card (if there is one) or delete some files or uninstal any apps that you no longer use. If you have room to install it there is an app called DiskUsage on playstore which gives a good graphical view of what is using memory.
Hope this helps. If you need more help I suggest you register on the forums and pay a question in the forum for your specific phone.
Roger
