Not enough storage after update
  • Start date Start date
A
Android Question
Guest
Dear people,
After my ASUS memopad hd7 updated i keep getting the message there is not enough storage available when i try to update apps via the play store. There is over 300mb available on my internal memory and plenty on my sd card. This is what i tried so far but nothing helped permanently.
-clearing the cache
-having most apps copied to my sd card
-made a new account. This solved the problem that i could not connect to the play store at all. After this I was able to update two apps manually until i got the storage problem error again.
-removing data and updates playstore.
-trying a fix involving deleting some stuff from the data folder, but on my device this folder is already empty.
So concluding, i have no idea what to do next. Please help me out!
You tried everything buddy, one last thing remaining is first take complete backup of the data through PC connection and then reset the device. Once it gets reset then re-install everything back. I hope its going to work. It worked in my case few months ago! Cheers :)
