Help Not enough storage space available
Gabo99
Help.... My apps try to update themselves, but everytime they do an error appears that says: Not enough storage space available. Or in my language. El espacio de almacenamiento disponible no es suficiente.
I have an S3 with 16gb space and i got 2 gb free still... Any ideas?
Thanks
Thanks
Clear the cache of each application (MENU>SETTINGS>APPLICATIONS & select each application & clear the cache if the option is present). Bettet yet, install a cache cleaning application from the GOOGLE PLAY STORE.
BTW.......
WELCOME TO ANDROID FORUMS!
BTW.......
I know Apps2SD will clear the cache
https://play.google.com/store/apps/details?id=com.wongxming.android.app2sd&hl=en
I'm sure there are plenty others.
Was looking at an HTC One S the other day that said it was full and there was over 500MB that had to be cleared from the cache!
I had a similar problem with a Samsung Tab 2.
A message kept coming up, "not enough storage space..."
I had 3.4 GB of videos stored and was unable to open my "Gallery". Also, I was unable use my camera and was unable to delete the unwanted videos that were gunking up my tablet.
Samsung support directed me to do the following.
- Press to open the "Apps" icon on the home page
- Press to open "My Files"
- Press to open "sdcard0"
- Press to open "DCIM"
- Press to open "Camera"
At this point all our photos and videos will be listed.
- Check the box beside the videos you want to delete.
- Press the " trash can" icon at the top of the screen
- And - Poof- those videos are gone
If you delete enough videos and open up enough space your camera and "Gallery" should be operational again
