Help Not Receiving Calls
dil_s13
Member
-AT&T HTC One (M8)
-Unlocked
-S-Off
-CM 12.1-20150929 Nightly
-I am neither sure when this issue started, nor sure what I could have changed for the issue to be caused.
-Any help is much appreciated.
@EarlyMon @Granite1
Are you able to make calls, and have good signal strength, the obvious things I can think of first. It might even in be a network problem in your area, could be worth checking with AT&T, see if there's any reported ongoing problems.
Have you tried your AT&T SIM in another phone, or another carrier's SIM in your M8? Which should prove if it's the phone, SIM or the network at fault.
