Something went wrong during setup and you likely don't have the correct Access Point Names. This is individual to the Sim/Carrier so you may need to contact your carrier or hope that someone else on these forums is on the same network as you and can help you set up your sim with the device properly.
Also make sure you're device is not locked to a carrier different to the SIM card you're attempting to use.
