not registred on network
  • Thread starter Thread starter attia
  • Start date Start date
A
attia
Guest
when i enter the sim
the phone display an error msg
not registered on network
but my internet bukect goes on
what should i do
Hello and welcome to Android Forums. Hopefully I can help you with your problem.
Personally, I would try contacting your service provider (carrier). Their customer service department should be able to walk you through the steps to enable your SIM card.
If it's still not working after you have followed their steps, it may mean your SIM card is bad. That or the SIM slot in the phone may not be working properly. You will not know unless you let them help you set it up correctly.
If you have any other questions regarding your device, I invite you to join Android Forums. We have many sections for specific devices which contain a wealth of information.
