Help Not sure if memory is enough for games
subphone
Hi everyone,
I never had Android cell phone, and I want to buy a Android cell phone. Right now I'm thinking of getting Huawei Mercury (M886).
I'm not sure if it's a good cell phone for something like I want to have a lot of high quality games like Evolution soccer 2012, a lot of app, and etc. So I'm not sure if this cell phone can handle all this with the memory it has.
So After installation all app and games, does cell phone be still work well ? wouldn't be slow ? do you think processor speed 1.4Ghz can make it and enough speed?
What is ROM ? is 4GB enough, and do you think 512 MB is plenty and enough ram for having a lot of games and app?
What is Storage Capacity ? And what does Storage Capacity do? Is 64 GB Good ?
And what they mean 2GB internet memory ? well I'm pretty sure is not the speed of Internet because the speed is 3G (Data Transfer Speed: 1x and 3G)
This is the information:
Thank you
Hey Subphone, I've moved your query to the Mercury subforum, where users of the device may be able to assist.
Looking at the specs of the phone though, I shouldn't imagine you'd have to much trouble.
At 500+ MB of internal RAM the mercury has enough memory for any game you throw at it. I have tried "heavy" games like asphault 5 and NOVA 2 amd they run flawlessly
Installing all those games wont cause the mercury to slow down, like any other phone though, it will if you run multiple "heavy" games all at the same time (like having 3 copies of Evolution Soccer running at the same time)
Having a 1.4 Ghz processor puts it at the high-end of processors it's more than enough to run the games you listed and more.
You seem to be talking about internal storage space. The mercury has 2GB of internal storage space, meaning that you have 2GB of space on the phone itself to store your apps and media and stuff. The 4 GB of ROM is for storing internal data such as system images, ect, dont worry about ROM size that much.
512MB is MORE than enough to run high end games. I tried NOVA2 (a high end halo clone) and I still had about 200MB of Ram left no nothing to worry about there.
Storage capacity is basically how much stuff (games, music, videos, ect) you can put on it. In this case it means the capacity of external storage (micro SD cards) it can handle. Micro SD cards are like tiny flash drives that slide into your phone to add to the storage the phone already has. So if it says up to 64GB that means that the phone can hand SD cards that can hold under 64GB. still 64GB is ALOT of space.
I think you mean internal memory. Confusing I know, but a better term would be "internal storage". This is the storage space inside the phone before adding the SD card. At 2GB it's still a good amout, but you should still get a micro SD card so that you will have even more space!
Yes 3G is the dataspeed you will get if you use your phone companie's plan. Remember if youre near a WiFi hotspot you can also use that for data usage. WiFi is much much faster than 3G (or 4G usually).
For detailed phone stats, I use GSMarena, they have alot more info on the mercury then the site you listed:
>>http://www.gsmarena.com/huawei_m886_mercury-4381.php<<
Good answers above. The only things I can add are the Mercury does only have a single core processor, so even though it is plenty fast some of the very highest end games may require a multi core processor. Also, the Mercury only has two points of multi touch on the screen, so the that into consideration for gaming unless you plan on getting a wireless controller.
When browsing google play on the mercury it will hide games from visibility that require more than 2 points of multi touch, such as Cross Fingers , luckily there arent many that require more than 2 points but it can be an issue with certain emulators.
I'm thinking of buying a cheap tablet to satisfy my android gaming needs at home, friend has a Kindle Fire and even tho its considered a lower end tablet it's cheap and runs games nicely (dual core CPU) plus the 7" screen goes a long way with the gaming experience.
