Help not synching anymore since a while
A
android man
Guest
hi all,
when i first used my motorola defy: google accounts, facebook widget, twitter widget, ...., were synching regularly; i mean when an email came in, phone sounds a noise, calendar gets automatically updated, ....
since a while, it doesn't anymore unless i do request the synch manually.
i've been digging into the settings and can't find anything wrong ....
anyone has an idea what's happening with my phone ?
thanks in advance,
me
Motoblur is a bit rubbish. If you find an account is not synching, remove and re add.
I have done this with Facebook a couple of times and with an exchange server once.
As a side issue battery performance may be lower as motoblur will be working very hard when failing to sync properly.
Olly
hi
did you get to the bottom of this problem?
I have recently upgraded to adroid 2.2 and since then i cannot get any twitter widgets to update automatically. i have to go into them and click refresh. on 2.1 they worked fine. this is so annoying! can anyone help please?
thanks.
