Help Not vibrating on type
Up until last night I had vibration when I typed, but now it doesn't! I've already checked the vibrate on key press option plus have turned haptic feedback all the way up and of course the vibration is on. I get the vibration when I press the home screen or get a notification, but not for messaging. Anyone have a suggestion?
if you are using the default samsung keyboard go to
settings > language and input > samsung keyboard (click the wheel looking icon next to it) then you will see the samsung keyboard option. make sure key -tap vibration is check. there u go.
i switch between swype and samsung keyboard. i know i check the -tap vibration for the samsung keyboard, but i am not getting the vibration. any idea?
** update... got it. you also need to go to settings-->sound to enable haptic feedback
okay i would of suggested that but thought u already had that on.
Go to Settings > Sound.... and then enable Haptic Feedback (and also enable it in the keyboard settings)
That worked for me.
