Note 10 check something for me USB transfer speed
  • Start date Start date
D
Deleted User
Guest
Can someone check with Samsung Galaxy Note 10.
How long is when transferring large videos when connecting to a computer or laptop?
Someone wanna check and see what they get?
also depends on where the files are going. are we talking about from pc to phone? and is the file going onto the sd card? or phone's internal storage? if the file goes onto the sd card, then the speed of the card will also determine transfer speeds.
pc to phone (internal storage). how long does the transmission take on your system?
OP, you wanna let people know what you're looking for? are you having an issue with your device? are you wanting to confirm if your speeds match others? you will get different results depending on how the files are encoded, how long the file is, the speed of the drive the file is on, how fast your computer is , even the cable itself can play a part.
then take any videos that are big and test for me. write later how long and how big the file was. thanks, buddy.
it will have to be later, as i'm currently drinking some good bourbon, smoking my cigar, and cooking my pork rib roast for my Xmas guests. maybe later this evening i will try as you suggest. and post my results. but as @marctronixx suggested my results may vary as my video file is going to be different from yours.
I transferred Iron Man, 1080P at 1.65GB. Took about 7 seconds. This was using USB C cable, on a USB 3.1 port on my PC. Copied directly to the Movie directory on the phone.
Here are my results: Samsung Galaxy Note 10 (512 GB).
PC with USB-C (USB 3.1) Port and Samsung Evo 850 SSD (1 TB) connected via SATA III and a USB-C (USB 3.1) cable taken. The included cable can only transfer USB 2.0 speed.
1. 4.06 GB (1 mkv video file)
2. 18.3 GB (18x 1 GB zip files)
PC -> Samsung Galaxy Note 10
1. 17 sec (244 MB/s)
2. 1 min 7 sec (175 MB/s)
Samsung Galaxy Note 10 -> PC
1. 31 sec (134 MB/s)
2. 1 min 41 sec (132 MB/s)
For comparison I have here an iPhone 11 Pro (256 GB) and Samsung Galaxy A7 (2017) (32 GB).
PC -> iPhone 11 Pro
1. 2 min 23 sec (29 MB/s)
2. 10 min 46 sec (29 MB/s)
iPhone 11 Pro -> PC
1. 2 min 32 sec (27 MB/s)
2. 11 min 30 sec (27 MB/s)
PC -> Samsung Galaxy A7 (2017)
1. 1 min 38 sec (42 MB/s)
2. 7 min 37 sec (41 MB/s)
Samsung Galaxy A7 (2017) -> PC
1. 1 min 59 sec (35 MB/s)
2. 9 min 28 sec (33 MB/s)
