RL in Florida
so i bought one of these
Amazon.com: Micro SATA Cables - PC USB 2.0 Cable Device Voltage Current Meter Tester: Electronics
and did some tests....with phone ON and phone OFF with various chargers i had lying around.
Here are the results.
I don't have the technical expertise to explain the results, but can assure you i tested each result at least five times to provide an accurate number. I am not going to report exact voltages here, but they range between 4.755 to 5.120. I think amps are the more interesting number:
Fairly controlled conditions. Phone at 50% battery. When on, all antennas turned off (GSM, GPS, WiFi). Screen Off.
The numbers are amperage/amps drawn:
Samsung Note 2 OEM 2A charger (white charger and cable in the box)
Phone ON: 0.83 amps
Phone OFF: 0.74 amps
Samsung OEM 700 mAmp charger (comes with the OEM charger stand)
Phone ON: 0.65 amps
Phone OFF: 0.55 amps
Anker Astro2 Portable USB Charger (Astro fully charged)
Amazon.com: [Upgraded Version] Anker
Phone ON: 0.83 amps
Phone ON: 0.65 amps
