There is the option to......Does anybody know if the LED indicator actually turns on, when the device is charging? That's something I've missed, ever since moving to the Photon. While I can use aftermarket apps that will activate the LED to turn on while charging, the light is so small that it was irrelevant.
I'd love to hear more input from peeps that currently own and are using the phone daily.
Does the note 2 have an led notification light like gs3 ?
Have the red LED lit when charging
The red LED lit when low on battery
Led light up with notifications (only when the screen is off)
Blue LED lights up when recording voice with screen off.
There you go![]()
Sorry didn't take a picture but yes it is prominent and yes it changes to green when fully charged.
on my htc phone... the led is solid orange when charging and turns solid green when done.
but I hate it.. because.. when it is plugged in.. the led only shows charging info.
so when a notification comes in, there is NO.. response from the led!
you have to wake up the phone.. to see if there is any missed notifications.
with the Note2..
when charging / plugged in...
does the LED still show notifications of messages?
example: blinking red or green?
this would be so helpful!
i used to use them... to get the 2nd LED (hidden) in the OG EVO to give me the extra info I wanted.
but i dont think the GN2 will have that 2nd LED.
I will try the apps you speak of.. when i get the new phone. just hoping that i dont need to...
I am using and have used Handcent SMS for a long time now and there are options to set
the LED notification a whole range of colours, tried one or two and they work well. Handy to
have a different colour for different things.
Yeah I think from my early Android days it was either Handcent or Go SMS, it just happened that I tried Handcent 1st, liked it so never tried Go. Yes there are lots of themes, skins etc, I just stuck with the metal skin with standard smileys (not the green Android ones) and then changed text tones for different people, nothing more annoying then getting a text message where you have to check it because it could be important, but its just a joke made up by a friend who thinks its funny.I was always content on using OEM text messaging apps, until I tried Go SMS. Thing is, it's been a little buggy lately, so I was considering trying Handcent, since it's so popular. Does Handcent have themes also? I just prefer the ICS color scheme and there were recent changes on Go SMS that I think made it a little too much for my tastes (plain black background turned into black w/ some weird pattern/design).
Looks like lightflow will allow for the multi-color LED to come to life!
Source:
Samsung Galaxy Note II Review - Samsung Finally Finds Their Killer App
Wow, that was a really negative review lol
