Note 2 won't turn on
  • Start date Start date
A
Android Question
Guest
Hi!
So my audio jack was broke so took it apart and replace with a new one. First I remove battery and sim card...then unscrew all the philip screw. Romove the metal frame and unscrew one screw for the antenna. Disconnect the mother board connection and replace with a new audio jack...made sure everything is connected and put all back together. When I went to start it up, nothing would work...I tried charging it while powering up won't work either. Any Idea?
