ahjengmool
Member
besides the new IR blaster, the note 3 s-pen will active the back and menu key, was shown in the 18 min. Samsung video,,,, does anyone know for a fact if wireless charging can be done similiar to note 2.
To secure your data, KNOX and associated data is deleted when the password is
entered incorrectly several times.
Another feature I find fascinating is Knox.
Apparently the apps and app data in it are password protected and completely separate from the rest of the phone: separate app drawer, app settings, data, everything. Sounds great for my banking apps and maybe enterprise documents, right?
So if you get it wrong - or worse, someone tries to get in, it just deletes all your apps and data? How about snap a photo of the offending would-be data thief and just protect the data? Why on EARTH would Samsung create such a useful (and thoroughly self-destructing) app like Knox?
(my emphasis)Note 3 User Guide said:To secure your data, KNOX and associated data is deleted when the password is entered incorrectly several times.
(my emphasis)
I think (well, I hope) that it would just delete the KNOX app and any apps that you had associated with it. So if for instance, I use two banking apps, if someone tried to get in to the phone, it would delete KNOX and those two apps but leave everything else intact.
So what you're saying is that you would HOPE that Knox, your banking apps and all associated data would be deleted at the first sign of tampering? No, no thank you.
Cerberus is a great anti-theft app in Play that does what I said: too many login attempts or pattern mistakes and it silently takes their pic and emails it to you. Lots of other stuff. But deleting everything should be a last resort, not a first one.
BUT... according to the Note 3 manual, page 145 covers Knox and warns:
Anybody figured out where the NFC is located? I hope they didn't move it back into the battery, like the original Note.
Your device allows you to read near field communication (NFC) tags that contain information about products. You can also use this feature to make payments and buy tickets for transportation or events after downloading the required applications.
The battery contains a built-in NFC antenna. Handle the battery carefully to avoid damaging the NFC antenna.
If the screen is locked, your device will not read NFC tags or receive data.
To activate the NFC feature, on the Applications screen, tap Settings→Connections→NFC.
Drag the NFC switch to the right.
Per the manual:
Now that I've made the decision and ordered the phone, I'm enjoying the process of learning all I can about it. Here we have a smartphone so heavily equipped with a plethora of features, it promises to provide hours of interesting discovery and plenty of time saving features.
Thanks for the feedback.The only real "new" feature they introduced was the S-pen airview thing (whatever it's called). There are other basic s-pen techniques that have even translated over from the original Note.
