Galaxy Note 3 users: how easy is it to hand write lengthy notes (such as during class) and convert them to electronic documents (such as pdf or word docs)?
That depends. With my handwriting, reading my notes 5 seconds after I write them is a major problem, but the Note 3 seems to do a better job of it than I can.
(And you can always pop up the keyboard and correct something the handwriting software totally screwed up.) BTW, if you're pre-med, I give "how to write totally illegible scripts" courses.
