Help Note 3 lollipop at&t
I have a att note 3 unlocked on the t mobile network. I keep trying to get the lollipop update through kies but keeps saying firmware up to date. Anyone know why?
I read somewhere else that the update wont come thru Kies anymore. I have an unlocked note 3 on ATT and got the update OTA a few weeks ago when i bought it.
may be rolling out in different areas. i would usually force it to check for updates, but the notification popped up for me. I wonder if it's because you're using T-mobile?
Rooted... you should not take updates that are official.
you need to use ROMs that are updated by the dev groups. For your particular phone.
ATT
Note3
there are some ROM that use an app to install them. directly on your phone.
you should ask in the Dev forum of ATT Note3. see if someone will direct you to one.
