My method is to plug the N3 into my PC, browse it from Computer or My Computer, depending on your version of Windows, copy the file(s) to a folder I created on the sd card called Documents, then open whatever PDF I want to read in the Polaris Office app.
You could also use the My Files app to browse to the Documents folder, and open a PDF by just tapping on it.
There's probably a file manager app out there somewhere that will let you create a home screen shortcut to documents, but I've never gone looking.
