AnonGuy
LolSuch restrained reasoning is too wise for these inherently compulsive forums![]()
Yes much faster. The Note 3 and S4 are both faster than the S3 and Note 2.True the S4 and Note 3 are not exactly the fastest to focus. Note 4 faster?![]()
GSMarena review says battery life is a little better than the N3 and over three hours more screen on time than the G3. Given the G3 has a smaller display, that points out how much a power piggy the G3 display really is.
The review mentions the G3 in comparison and points out the much shorter battery life for real use, rather than weighing with short SOT as other reviews did.
The 300 mah would bridge about 30 minutes at best and then that is offset since a smaller display.Well, the g3 is 300mah less than the Note 4, at 3k mah, so that should be a consideration as well. The g3 gets better screen on time than the Note 2 did and the Note 2 had same size screen and was only 720p. That is just comparing when I had the Note 2, which to me was awesome (imo, better than note 3).
All I get is a white page!
:hmpf:
Can someone please help me make sense out of the reviews of the processor/performance of the Note4? I have read reviews that suggest it may not be faster than the Note3 in some areas and the iPhone 6 is much faster than the Note4 in tests. Are these just benchmarks? In real world usage is it a different story?
Thanks.
what do you mean by off screen tests and on screen ones? Do you mean tests with the screen either on or off? If so, what is that showing?
Thanks.
After using the N4 since launch and having spent a good amount of time with the N3 before that, the N4 is great but IMO not worth the jump- if paying full price.
The N3 is still a great device even after a year. If I had the N3 instead of the S4, I would probably not upgrade. JMO.
Of course, I do have the N4 now and my perspective would probably change if the N5 has a 64GB option with sd and 64bit chipset next year. Yep, it probably would.
A few things with perspective coming from years in consumer electronics as an analyst, marketing and a geek.I can't convince myself to make the switch. I'm on a regular VZW plan ($299 to switch), don't think I'm missing anything with finger-swiper ID and the other new N4 stuff, am a little concerned about the reports of N4 shorter battery life, and basically just couldn't be happier with my N3's performance. And, since all of us in the US are getting 32-bit Snapdragon processors in the N4, I'm gonna hold out and wait until we're all converted to 64-bit (N5?). Can you imagine 6GB of RAM in this beast?!!?
Why being non-64-bit kills the Galaxy Note 4's futureproofing - Opinion - Trusted Reviews
There is such a thing. Devices that launched with older SoC last year didn't get OpenGL ES 3, which directly impacts game performance. Same for XLTE, Miracast, VoLTE, BTLE and other features. A lot of people who bought "flagships" with older chips end found themselves missing features when they were added to the platform.A few things with perspective coming from years in consumer electronics as an analyst, marketing and a geek.
There is no such thing as future proof
Better to have a device and enjoy it rather than wait for the next best thing. The Note 5 is a year away as example.
Life is short, but tech life is even shorter.
If you are going to keep a device for 2 years, then you really should be looking for something with current cutting edge hardware... Software can be made better. Hardware is forever.
If you worry that much buy an apple device.... They've not changed much for years
You seem from your earlier posts to be into cameras and screens --- me, I get more excited about easy file and data sharing, Multi-Window, and the S Pen. To each his own, eh? (But I do love that 5.7" screen.)
