Note 4 and iPhone 6
bad1550
Has anyone used both the Note 4 and iPhone 6 Plus on one line and is it possible ?
Thinking of picking up Note 4 as a 2nd Phone
Well honestly coming from an iPhone 4S to Note 4, it's hard to compare the running two different operating systems, but I will say I use Note 4 as a daily driver and I love it there r a few things I miss with iOS but over all Note 4 is much better device for longer battery life and alot more storage space but it's all personal preference.
I'm glad I didn't buy iPhone 6. Plus I'd b very unhappy since iOS 7 and iOS 8 is just worse yet...
I can't say iPhones r bad cause I do own them, just they r very expensive for nothing. My iPhone 4S is pretty much same as iPhone 6 yes they made screen bigger but and it's a bit faster but features I have all the same... and if you want faster performance Note 4 opens an runs apps fast, which in my opinion is very sad on apples part since it's running on a low screen resolution.
If I had the money I'd buy both an Switch daily but I don't. iPhone r the same in every generation, an 16gb hard drive is nothing and I have to change it 2-3 times a day.
My Note 4 runs 17 hours with 6 and half hours on on screen time. No iPhone is goin to last that long!
I think that's more of a carrier question, yes?
At one time mine would just let me go online and swap phones at will - mine were carrier locked though.
So, what carrier are you on?
Also you can use one line, but the need to both GSM phones an either but from same carrier or one or both Sim unlocked, your only problem would b is a nano sim and micro sim with switching, you'd need to get a micro sim template to place a nano sim inside it. iPhones 5 and up uses nano sim, Note 4 uses micro sim, an switching phones is easy as switching sim cards,
I can switch from my iPhone 4S to my Note 4 r since both r micro sim and both are from AT&T tho iPhone 4S is factory unlocked an I'm goin to factory unlock my Note 4 as well
Thanks for all the help
I'm switching from verizon to ATT
I have iPhone 6 Plus which is unlocked but if I buy note 4 from retail store can I interchange both with an adapter?
More than likely you should b able to just since the iPhone 6 plus is a Verizon phone correct? Factor unlocked, it will b able to read AT&T service you just won't have true 4G/LTE cause the antenna with a CDMA phone can only read certain bandwidth on a GSM Network, an guessing you'd buy Note 4 from AT&T, than all you'd need is nano sim to micro adapter, an can switch phones, so you'd need to have a programed nano sim, an have a footprint of a micro that fits so it's fits, I don't have any phones with nano, but I can say I use to do this with older iPhones with Mini sim an Micro sim. (Like iPhone 3Gs that used Mini sim cards and iPhone 4S that used micro sim)
retail stores won't have this like adaptor, best is to look on amazon or do some research about it first, an make sure your Verizon iPhone 6 plus will work on AT&T, I hate CDMA phones :/
But I made mine with from an old credit card an used a box cutter an cut out the footprint to make it fit inside, I was cheap about it but it worked for time being
I appreciate the help
Just got back from ATT. I ported my iPhone 6 plus from Verizon
When I pick up Note 4 at retail price I will try the switch with adapter.
Thanks
