Help Note 4 Duos - N9100
JINUJK
I purchased note4 from ebay -N9100 dual sim chinese version. It came rooted and the version is kitkat 4.4.4. i want to update the software to new lollipop. i tried through ODIN but it says Fail. ( N9100ZHU1BOF2_N9100ZZH1BOF2_N9100ZHU1BOF2 firmware). It can't boot up now. displays "Firmware upgrade encountered an issue" Please select recovery modein kies & try again.
Please help to get it updated to new version. My battery is draining heavily now and want to check if it solves with the new lollipop.
How to check the correct version of software for N9100?
ODIN says :
<ID:0/007> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> N9100ZHU1BOF2_N9100ZZH1BOF2_N9100ZHU1BOF2_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/007> Odin v.3 engine (ID:7)..
<ID:0/007> File analysis..
<ID:0/007> SetupConnection..
<ID:0/007> Initialzation..
<ID:0/007> Get PIT for mapping..
<ID:0/007> Firmware update start..
<ID:0/007> aboot.mbn
<ID:0/007> NAND Write Start!!
<ID:0/007> sbl1.mbn
<ID:0/007> rpm.mbn
<ID:0/007> tz.mbn
<ID:0/007> sdi.mbn
<ID:0/007> NON-HLOS.bin
Go to the sammobile website and type in your model number into the search (which you find in the about phone section of the settings). I looked for my country/carrier in the list and downloaded the newest version. The odin flash worked first time for me.
Good luck!
Regards,
Eric.
