Help Note 4 home button?
After I upgraded to lollipop, sometimes when I hit the home button to exit and go to the home screen it does nothing. I have to hit it a second time to get it to work. I've cleared cache with no change. Anyone else experience this?
Thx.
I had a problem with my old s5, when you hit the home button it would take you to Google search bar. I restarted the phone and it seemed to work fine after that. Not sure if that is your issue, but you might try it.
