Help Note 4 N910C vs N910S
picard25
Hi,
I live in the UK where the model is N910S with the Snapdragon processor. However I can get the N910C with the Exynos processor which is faster.Can anyone see a problem with me getting the 'C' version -apps not working/incompatible functions??
Thanks.
I don't think there is a real difference with apps or functionality.
From what I've been reading though, the main difference seems to be battery performance. The Exynos seems to be a little more power hungry than the Snapdragon.
I have not been in a position to examine the two devices side by side, so my comments should be taken anecdotally at best.
Well,I have just ordered the 910C because,as far as I know,the UK & South Korea are on good terms so the phone should be fine :-)
Unlike my daughter,I can moderate my mobile usage so,hopefully,the battery life should not be a problem.
Thank you again for your input.
I would suggest getting which ever is better supported where you are (Warranty etc...), thd 'C' also only has LTE Cat.4 and not Cat.6 like the Snapdragon.
There is not much difference in them.
Thank you for your input but as I said in my previous post I have ordered the 910C.
Based on a tiny bit of research CAT4 is more than enough for the UK.You might hit that in a couple of the big cities but not my area + I do not d/load that much outside of my home.
I fully agree you should buy the best for your area but,sometimes,you have to have a bit of excitement as well :)
