Help Note 4 SD card issue
N
Note 4 SD card read issue
Guest
Hello all,
I have a Note 4 (SM-N910T on stock rooted 5.0.1) that suddenly started having issues with a specific microSD card. The card works perfectly in my computer and my S4, and my Note 4 can read other cards without issue. So it seems to be an issue with this specific card in this specific phone.
The phone can mount/unmount the card fine through settings, and correctly reads the storage space used and available. When I use the Samsung file browser (My Files), it just says "No Files." I also use FX File Manager, and with that I get "Access denied" when trying to open the card. FX is unable to display anything regarding storage space, it just says "Error."
I'll format if I have to, but I'm hoping somebody has another solution!
Back up the data on that card immediately - this might be the first sign that the card is starting to fail.
If that's not it then I don't have a solution. But I'm advising a backup now because I have seen cards fail with very little warning, so best to save the data just in case.
I agree, once those things burp, get a new one... now, not later when you are crying in your beer.
