Help Note 4 Speaker on be default when make or answer call
Hi,
I have problem appeared last few days in my Samsung Note 4 Device
Whenever I answer or make a call automatically it turn the speaker on then I have to turn it off on each call.
I googled an found a lot of people facing the same problem, but there is no specific fix for it.
I tried my self to remove last two applications I installed and tried to use this app as a workaround solution:
Auto Speaker - Android Apps on Google Play
https://play.google.com/store/apps/details?id=com.hanan.android.ramkol&hl=en
but still no luck.
Any one could help with a solution please?
Please forget about "Format" or "Factory Reset" options I just did it month a go, and I don't need to do it again =.(
