A
Android Question
Guest
TLDR: Phone kept crashing, reflashed latest firmware w/Odin, phone now only boots to recovery mode or into download mode.
I posted this at Android Central but didn't receive help:
First Post: I have had my note 4 for about a year now and it has recently began to act funny. About a month ago it began to randomly freeze and slow down. Now it does it more often (about once an hour on average) and just this week it has been crashing randomly. Yesterday it crashed and went into recovery mode, displaying the android guy and "downloading, do not turn off target" with "could not perform regular boot" at the top of the screen among other text. It's done this twice now and the only way to get out of recovery mode is to pull the battery. It also will take a long time to boot up, or get stuck in a boot loop for 5 or so minutes.
I have done a factory reset and unmounted the SD card (someone suggested it may be corrupt and causing this). I've also cleared the cache partition to try to fix this, but while booting into recovery it said it was installing a system update for 15 minutes, then said something like "no target" (cant remember exactly) with a dead android guy. After clearing the cache partition, it got stuck in another boot loop and again randomly went into the recovery "download" mode. So far i have been able to get it to boot back up again after each crash, and i can't find a pattern as to when the phone freezes and crashes.
Second Post: So I decided to reflash the firmware myself. I downloaded ODIN, the Samsung USB drivers, and the most recent Sprint Note 4 release I could find (android 5.1.1, specifically a file called "ALL_SPT_N910PVPU4COG5_N910PSPT4COG5_CL5303209_QB5691107_REV00_user_low_ship_MULTI_CERT.tar.md5.zip" from theandroidsoul.com). Following instructions, I flashed the firmware successfully, according to ODIN, but when the phone was supposed to reboot at the end of the flashing process, it appeared to stay off. Pressing the power button or any other combination of buttons did nothing until i removed the battery. The phone booted directly into recovery mode, so i did a hard reset from the recovery screen and flashed the firmware again.
Now my phone either boots directly into recovery mode or directly into download mode. When i tell it to reboot or turn off at the recovery menu it will become unresponsive with a black screen until i pull the battery. I have tried flashing the firmware again, but with the same results. I am not sure what to do at this point. After the second flash, the phone appeared to begin booting normally, displaying the green android guy with a small loading bar underneath, but the loading bar got half way and disappeared, then the phone went into recovery mode. UGH.
Hopefully you fine gentlemen and/or gentleladies can help me resolve this issue.
can it be that the motherboard is defect?
