Help Note 5 - Echo sound when using Bluetooth headphones
gjkiii
Member
Hello. I have a note 5 on Tmobile. Starting today anytime I use bluetooth headphones on you tube there is a huge echo. If I use wired headphones then it sounds fine. I have tried multiple headphones and have unpaired them and re-paired the headphone and the echo is still there. Does anyone have any idea what to do? Thanks
Are using the YouTube app or Mobile version? If it's the app have you cleared the app cache maybe even the data? Is YouTube the only app you have this issue with? Is the app up to date? If you are using the app have you tried the mobile version to see if you have the same issues?
