Crazy,but,no option to change the lockscreen short cuts,or,eliminate/hide 'em either.look under your lockscreen settings, do you have an option for shortcuts that allows you to change/delete them? i have an lg so im not sure if the option is in the same place on the note 5 but thats where they are for me...if you dont see it there, perhaps its under the display settings?
Booo I upgraded from a g2 and this will be the second feature that doesn't exist so I have to get an app. Are there any you recommend just for apps to be add I don't have a need to actually lock my phone.WELCOME TO ANDROID FORUMS Heather Row !
The only option at this time is to use a 3rd party lockscreen app.
https://play.google.com/store/search?q=lockscreen apps&c=apps
If you don't need to actually lock your phone,you can select NONE under Lockscreen settings & set up one of your desktop pages w/the shortcuts that you were wanting to use on a lockscreen.Booo I upgraded from a g2 and this will be the second feature that doesn't exist so I have to get an app. Are there any you recommend just for apps to be add I don't have a need to actually lock my phone.
