Looks like it's been trying to sync with the cloud. Did you let it sync over cloud from your previous phone? I say you're better off using the USB cable and adapter that came included.
I just let it replace with the "factory version" and it would disable. :shrug: Dunno if that's the correct way or not.Okay, how the heck do you disable apps on the Verizon Note7? Do you have to first replace the app and then disable it? Every time I try to disable bloatware, I'm prompted to cancel or replace.
Not saying that doing what it suggest there doesn't help with battery life but I haven't turned off anything crazy and i get 24hrs from my phone at like 4hrs screen on time. That's still using the always on display.Most of the google apps can be disabled by holding down on the app and moving to disable. Also, to assist with battery life, you need to disable a bunch of items. Also check out the following site for some simple tips. https://www.gottabemobile.com/2016/08/19/how-to-fix-bad-galaxy-note-7-battery-life/
This really helped.
Did you copy over your phone settings and app to your new phone or start fresh on your Note 7? From my experience, porting over settings and apps from my old phone was convenient but then eventually find stuff that do not work properly. Some issues I found were, overheating, battery drain, bluetooth dropping out, google voice detection is spotty etc.
I've learned my lesson and just always start fresh and skip the option to restore my phone settings/apps from my previous phone.
