Note 7 Edge Notification Feeds
droidbillh
Has anyone seen the edge notification feeds on the Note 7 ?
I'd really like to know how they compare to the S7 Edge.
Thank you !
I did see this. I'm referring to the notification feeds that scroll directly on the edge -sports scores, notifications, etc
I didn't know the S7 Edge had a scrolling display... I thought the Note Edge did. The Note 7's edge is so thin and the curve so sharp, I'm not sure how a scrolling display would work on it. I guess we'll find out in two weeks!
I'm going to try a Note 7 this weekend to see for myself.
It is too thin so if it does work it will be distorted and not the same legible angle as the S7E. The only apps shown so far use little side strips and that function is no different than side swiping with a flat display. Seems the only real function of the curve is to make the device thinner so can still claim 5.7".
Best Buy in Spring, Texas had one on display that was a working model when i pre-ordered mine. that was last tuesday... (Spring is just North of Houston)
See my post with the Facebook link for a picture
Here it is
doesn't really look like its on the edge part, just a side scrolling test on the main part of the screen...hmm
