Note 9 to Ultra
My S21 Ultra is due tomorrow.
I currently have a Note 9.
My plan is to put the sim from the note 9 into the ultra.
Setup the Ultra, then use a Type C cable, to connect the Note 9 and the Ultra.
I then plan to use SmartSwitch to transfer all the "stuff" to the Ultra.
Can anyone tell me if my plan is OK or otherwise.
i have used smart switch going from a note 8 to the note 10+......never had any issues. you plan sounds solid to me.
Well the switch to the S21 Ultra went perfectly.
I left the sim in the note 9 until the smart switch was complete then inserted the sim in the S21 Ultra
It is an impressive phone.
