Help Note connects to wifi but not to internet
Hi all,
I have a Note running Jelly Bean 4.0.4. I've been having persistent problems with its inability to connect to my home Wifi network. I'm running a NEXT 1105-NF that is 802.11n capable (I live in South Korea, hence the strange router name). My wifi network works fine on my Macbook and iPad, but my Note will absolutely not access the internet.
I've cycled through every form of security it supports, even dropping it down to having security disabled (just as a test). In every case, my Note will connect to the network, but then not have a connection to the internet. I've cycled through the network channels from auto all the way to 11, and my firmware is the most updated version. It's beyond obnoxious having to use my limited 4G allowance at home, since my network works on other devices.
Does anyone have any suggestions? Maybe there is a potential solution that I haven't tried. Thanks!
on the bat it is only at home you not connecting? then it is with your Wi-Fi configurations giving you trouble.
