if you go to settings>applications>manage applications....scroll down to the app in question...select it and if its possible you will then have the option to move to SD card
The problem with the Note's crappy memory design... it's only 2GB out of the 16GB... and many apps somehow must be parked in this 2GB portion for it to work. Some of the apps could be moved partially to the balance 13+GB called SD Card (yeah... I know). And I really hate that stupid Google+ apps that takes SO MUCH memory in the 2GB space.... really wanna delete it... but understand I have to root my baby!
@sleedeane... no worries - we all learn from each other! Yup... ICS will come to the Note... just got a little delayedThat's exactly why I want ICS to come to my T-mobile S2: I understand ICS will let you "disable" most of the craptory bloat.
(I'm afraid to try to root "my baby". I've bricked enough phones to ever try that again).
Does the Note get ICS? (shows you how little I know).
(I should sign my posts "clueless in Missouri")
Strange I only have 800 MB of memory !!!!
You sure you're not looking at RAM?
Maybe you are right. How much memory has the note. If my phone runs no applications almost 500MB of the 800 MB is already used. Is that not very much ???
