Help Note restarting?
mcluskyisms
Just wondered if anyone has had their Note rebooting quite a bit since updating to 4.0.3?
Mine keeps rebooting (not constantly, but enough to be annoying) when Im not using the handset. I upgraded to the 4.0.4 today and its still doing it?
Any ideas on how to stop it?
I'm not 100% sure about this but since I turned off auto update apps I've gone from 2-4 reboots a day to 167 continuous hours without a reboot.
Cool, I know you can choose not select auto-update on installation of most apps but is there a master setting to stop all auto-updates on all apps? Deffo worth a try as its becoming more than annoying.
Will apps request to be updated if auto-update is switched off also?
Cheers!
Chris
