Mariusz Chmielewski
Hi Guys,
I have owned Note 2 since 2013 - it worked fine up till now. Recently I have disassembled the device and worked with the jack port (had some problems with the connections). I managed to solve the problem with the port - unfortunately after an hour the device reset and the GalaxyNote 2 logo came out - when I connected the USB charger the logo stayed for a while and then the phone shut off. After that incident I have tried to turn back on the device with no results. The phone is dead. I have tried 3 different batteries, connecting the phone to computer, charging the batteries outside the phone etc. I have also tried to hard and soft reset the phone - still no luck.
I am running out of ideas - can anybody point me how to diagnose the software, firmware or hardware problem with the phone?
P.S. - I see no damage to the circuits, everything is connected I noticed that the sim card slot gets warmer when I try to turn back on the device. I have stock ROM - no modifications.
Thank You in Advance.,
