IMO the only reason the Note 6 gets dibs is if a person insists on having the newest OS as soon as possible and mod centric. I find the device more a priority over a newer shinier OS and the Note 4 already has the ability to shut all the bloat and bling (IMO) sensors off. Wiz is fine, but can be replaced with other UI if wanted.
The only thing I am missing is card writes and not missing them on my phone like I thought I would. I would on my tablet, but my Note 2014 is on 4.3 and will stay there until L is released and IF has card writes.
Besides update advantages, all I see are disadvantages compared to the N4:
No Sd slot
Inferior display
Inferior camera
Fix battery
Bigger
Not seeing the allure unless obsessed with the fastest up updates and for modders.
The argument in favor of the Nexus 6 is simple and straightforward.
We all have different needs priorities and workflows or personal patterns we use our smartphones for.
In my case if I'm being honest I'd be very happy if it came without a camera. Forty smartphones over the years and I've never used the camera because my preference and practice is to use a small ergonomically comfortable Nikon digital that goes everywhere with me. Obviously I'm in the greater minority but that's an example.
Next is the fact that the six inch display is a huge advantage for my needs and preferences. My workflow involves spending lots of time with desktop versions of web sites which are much easier to view on a large display.
I have large hands which makes this phone very comfortable to hold.
I happen to be very happy with Android 4.4.4.therefore once again Android 5.0 is far from a must have for me.
Battery life is never a deal breaker for me, even though my phone sees heavy usage, always carrying a compact and light bag for my MacBook Air I tuck in a small Anker external 12,000 mAh battery that makes topping up my phone or iPad very fast and easy.
Everything I've read suggests it'll have similar if not the very same display technology as the stellar Note 3 / 4 models.
I have no use for an SD card so that's not an issue.
Therefore for my needs the Nexus 6 is just ideal, it's the phone I've waited years for.
So there you have it, Nexus 6, my ideal smartphone and a wonderful example of the power of Android and the choices we have amongst the various handset makers.
