A Android Question Guest Nov 12, 2015 #1 I cannot access my note 5 settings. If i access it it would say unfortunetly settings had stop.
glc Android Enthusiast Nov 12, 2015 #2 It would be helpful if you told us what you did prior to this problem appearing. Also, what version of Android are you running?
Jfalls63 Android Expert Nov 12, 2015 #3 If you haven't rooted and deleted any system apps a factory reset might fix your problem.
