Notepad for android
gwatler14
Hi can you please advise me how to go about getting a Notepad application to install on a Android and also an application that closes all applications that is running on the android.
Thanks
George :confused:
Hello and Welcome to AndroidForums!
For a notepad might I suggest "ColorNote". It's what I use. It's easy and even has a widget!
For a task killer use "Advance Task Killer Pro". It's free and does the job very well.
Again, welcome and I hope you have a great day!
~ ArmyX
Thanks
George :confused:
Hello and welcome aboard. Thanks for joining the Forums.
Okay, first thing...here is one of the best application note everything you'll ever need for that purpose. Second, I'm not sure of which device you have, but a task manager isn't really needed for these types of smartphones. Here is why?
I hope the above info will be helpful to you. :)
