Notes help please.....
wedgemoose
This is my last "Sense" type question. I have found similar stuff for everything else i was needing.
The number ONE widget/app used on my t-bolt was the "note" widget. It was great. Just click on it, write a note and it was there. Then when you made a new note it just went on top of the older ones. And you could flick through them to read.
I can't find one that doesn't take less than three or four clicks to use. Some you have to go into widgets each time and add to a screen.
Is there any similar or easy to use like the HTC one? It's the most important thing I need.
Thanks
