Accessories Noticable difference between Class 2 and 4 16Gb microSD?
It won's slow down your Evo ... but it is a slower transfer rate when transferring between computer and card.
My guess .... you won't see much of a difference between class 2 or 4.
Yes, 8gb card that comes with evo is a 2.
The higher the Class rating the higher the read/write rate on the SD Card.
Class 2: 16 Mbit/s (2 MB/s)
Class 4: 32 Mbit/s (4 MB/s)
Class 6: 48 Mbit/s (6 MB/s)
Class 10: 80 Mbit/s (10 MB/s)
The higher the better for transfer rates if you plug it directly in to your computer... When it tranfered my stuff from my class 6 to my computer it was blazing... but when i re-transfered from my pc to the class 2 8gig that came with the phone... it was SLLOOOOWW.
I dont think the phone cares what class it uses, but a computer media reader does :).
PS photographers need higher class ratings for faster shooting for their fancy cameras.
ok so heres my question, android OS supports 32 gig cards right???
what is the fastest 32 gig card anyone has found that should work with my phone?
this is the only one i found but its 200$ !!!!
SanDisk
