Root Notification Center Glitch after xposed framework
iamjwb
Does anyone know how to fix this. I rooted and installed xposed framework. After tweaking some things, I noticed this glitch. It is very subtle but bothers me.
When you pull down the notification bar, in between the clock and the all clear button, it is grey - ish instead of being black all the way across. I used gravity box and tinted statusbar before noticing this.
Hope that isn't too confusing
if you noticed this after "tweaking things", untweak it and see if it goes away. Modules can cause all sorts of issues. Its easier to disable the module, reboot and see if the issue goes away. once it does, then you'll know what module caused it.
I tried that and I can't find what caused it. I uninstalled all the modules and did a factory reset but it didn't fix it.
Not positive this will work, I'll try later now that reading this made me realize mine is like this as well and I never used xposed, but try something like rom toolbox (I think) that can change your status bar and just change the color to black or whatever desired color and see if that fixes it.
Are you using ADW Launcher by any chance?
