Hi All,
New poster so please be gentle!
I have a HTC one x with a problem.
Yesterday for no apparent reason, after disconnecting the stock HTC charger, the phone display indicated it was still charging. The LED light was stuck on solid red, and the battery indicator was scrolling.
I soft reset the phone a couple of times and the issue stayed.
I stopped all apps, no change
I then did a hard reset and things seemed to be OK.
The battery was flat so gave it another charge till the notification LED turned solid green.
After removing the power cord this time, the LED stayed on solid green. I did a normal soft reset and the LED switched to solid red.
I then did the latest software update to version 3.14.401.31
The light is still solid red. Even when I power down the phone the LED notification light stays on solid red.
There are now no 3rd party applications installed on the phone (there was only one previously which was blueDUN to enable functionality with the car)
Apart from the LED light being stuck on, the phone appears to function normally.
The phone hasn't been dropped, damaged or been near water. It has been in a protective case from day 1.
Any ideas on how I might be able to fix this? The phone is under warranty so I can take it in, but I'd rather avoid the hassle is there is a known fix for this.
Thanks in advance
D
Thanks in advance
D
