Notification LED
Lona808
So can someone please tell me when the notification LED takes effect? I've noticed it blink once when I got a text but that's it. I just came from an HTC One X and the LED on that phone continues to blink as long as the notification is active. Or if its charging it is solid. Is there a way to make the Nexus 5 behave like this or do we just get a quick blink that we'll only notice if we are looking at your phone.
I think it keeps blinking until you check the message. It's a pretty slow blink. I believe it only works when the display is off as well...
From what I've read, nobody has found a way to get a constant charge light yet.
Check out Light Flow for adjusting your notification leds. You can choose different colors and timing for different notifications. When I went through the colors I know for sure it can do white, red, yellow/orange, blue and purple.
App says some devices require root. I rooted straight out of the box so I'm not sure if this works on n5 without root or not.
The app lightflow gives you full customization over the led light. Everything from which color for which app as well has how fast to blink or to just keep it on when you receive on. There is a lite version that is free, but it doesn't offer as many features.
Edit: 8-bit ninjas are quick
So I've been playing around with Light Flow and I like it so far, but is there still no way to get LEDs when the screen is on?
