Notification not showing for S3
littlehid
Hi! :)
I've been using my S3 for about a month now. Everything is working fine until today. Suddenly the notifications are not showing. Before this I've downloaded the Easy Battery application, so the emoticon will show on my top left side screen. So whenever i have any notifications such as email, miscalls/sms or even whatsapp it will show next to the Easy Battery emoticon. I don't know what happened suddenly the Easy battery emoticon is gone but there is another symbol showing there (a small box with a minus sign). I tried to check any running applications but nothing seems to work. i even uninstall and reinstall Easy Battery but that's not the issue. Rebooted the phone several times still the symbol is there. Not sure what to do. It's hard because i don't see any notifications coming in and sometimes the sms/emails that i received are urgent matters. Can you help me?? PLEASE!
Hi! :)
I was having the same problem you.. I just found out I accidentally switch off my notification. All you need to do is switch it on again. Flip down your notification page, next to the "power saving" icon is the "notification" icon. Hope this helps
