I don't know what it is that you are asking. What I posted is the running Profile/Task exported as a Description to the clipboard and then pasted into the message. What are you asking?
The original solution would trigger every 24 hours at the same time. If you reboot the device it will also trigger right after the boot. The solution was to check when it is triggered to see if it is the desired time. If it is not then nothing happens. If it is then the action to occur every 24 hours happens.
The other change was to check to see if the global variable with the desired time is set. If it is set then nothing happens. If it isn't set then the desired time is set.
To change the desired time …
Update it in A2
Clear the global variable
Run TimeIt (this will see that it is not set and set it to the new value)
You should also note that this example is for 2:40pm. This could be identified as either 14:40 or 14.40. For the comparison to the current time to work it must be set as 14.40.
… Thom
Update it in A2
… Thom
